wiring under the hood
hoppalong
Hello everyone ! I am new here and I found this site while searching for an answer to my problem . I sure hope someone can help me here ! My problem is this----I have a 1988 XLT Ranger I am trying to put back on the road and one of the things I am doing is rewrapping a lot of the wiring in the engine compartment . I came across what I think is a resistor and it has a wire connected to each end and one wire is broken off too close to reconnect it . it is made of rubber ----measures 2 inches long by 1 inch wide by 1 half inch thick and has a symbol on each side that looks like a lightning bolt and the letters P9 on one side . I have tried to find it on a few electrical sites and online electrical diagrahms without any luck . If anyone can put me on the right track it will sure be appreciated .
Check this thread, specifically the linked picture RonD posted.
Thread here: http://www.therangerstation.com/forums/showthread.php?t=174359
It is the tachometer wire for the computer
It's non-connection won't prevent startup or driving
Computer also gets RPM from TFI module
But you should get code 18, if I remember correctly
Wrecking yards should have these, already removed and on the shelf
22k ohms Ford resistor, it was very common on all Fords of that vintage, not a Ranger thing
It was never sold separately by Ford
