Wiring thru firewall
1994xlt
Forum Member
Morton
IL - USA
Vehicle
Drive
Stock
Stock
good question
I’m putting spotlights on the back of my trucks bumper. How did you guys run the wiring harness from the battery thru the firewall I am putting the switch on the dash.
For a 1/4" hole, use a .22. You get a 3/8" hole with a .38 or 9mm, and use a .45 to get a 1/2" hole.
Or better yet, just poke your wires through the rubber grommet for the speedo cable.
Sounds good I’ll find that tomarrow
For one or two wires, it’s usually easy to push them through an existing grommet alongside the other wires.
We’re is the speedo cable grommet?
I’ve used existing grommets and I’ve drilled holes in convenient spots and just put my own grommet in. I’ve started working towards making things more modular though like the factory wiring but that is because I’ve had to take stuff apart and fix things so I’m shooting for making things easier on myself.
I gotcha
I need to get this wire thru my firewall the white end
  • Wiring thru firewall
Personally, I’d consider un-pinning the plastic plug and putting the pins back in after getting it through a smaller hole. You have to be a little careful doing that cuz you don’t want to mess up the pins or get them switched around in the plug, but I do electrical a lot and it’s no thing for me.
De-pin it.
If I think if it later this afternoon, I’ll do a short video on that to show you how.
The one
i have no clue on how to do that. Is there any other way to get this thing thru
De-pin it.
This truck is automatic could I shove it thru this?
Yeah, you can go there.
Or there's the hood release cable grommet shown here:
Definitely de-pin that wire to run it through, and put it through the rubber, not just beside it.
The clutch pedal cover?
I have no clue on how depin it I guess I’m gonna have to do this project another time I don’t know what I’m doing
Featured Ranger Based Vehicle
