Wiring Guru's....SPDT w/ LED wiring....
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
Salem, IN
Alright, I have a SPDT (on-off-on) switch with 2 LED's in it to wire up some lights. It has 3 prongs on 1/2 the back and 4 prongs on the other half. I need a wiring diagram helping me wire this sucker up.....Anyone wanna help?
There's a little more to this if you're looking at 7 prongs total. The "single pole double throw" (SPDT) part would account for 3 terminals only at the most, likely the 3 by themselves. Do you have any idea what this switch was originally used for? Maybe get some pics up of the switch?
it is a Contra switch. There was no "use" for it. It is sold as a SPDT switch.
This is what I am thinking...
I think that you're on the right track, as far as wiring the load (i.e., the lights; make sure the switch rating will handle them). This part would the 3 terminals, wired as in your drawing.*
What I'm thinking is that 2 LED lights in the switch are not bussed internally; but rather they're externally wired which accounts for the other 4 terminals.
You can try wiring it like in your diagram, and if the switch works, but doesn't light up, then you're looking at the 4 terminals needing to be wired for the LED lights. Hopefully, the LEDs already have resistors on them inside the switch. Otherwise, they'll need 5 volts instead of 12 volts.
Have you tried Googling "Contra switch" to see if you can find instructions for it? Good luck.
* Edit: there could be more than one possible wiring configuration, depending on the switch design. For example, the center pin could be common to the outer pins, depending on the switch position. In this case you'd have one power in, and only one power out to turn the lights on and off.
When in doubt, grab your trusty ohmmeter and see what gets connected to what as you throw the switch into each position.
i am going to check that when I get home!
got curious so i grabbed my volt/ohm meter out of my work truck.....that wiring diagram I have above is correct. I have to make sure I put the correct middle with the same top and bottom of the same side. They do not cross connect.
