Wiring for fog lights?
Special Ed
Hi all,
I have an '04 Ranger that has no fog lights but it does have the valances(?) for them (the holes are there with plastic inserts but no lights). My question is, would the truck already be wired (just not connected) or will I have to do all of the work of wiring myself? I'm not an electrician nor a real good back yard mechanic so I don't know what to look for.
The other option (where I'm leaning) is a bull bar where I can mount some nice big lights instead. Still, I'd like to know what I'd be up against if I went the route of using the stock locations.
Cheers,
John
I'm not to sure if there is a wire to tap into for a setup for factory fog lights, except the parking lamps, but if there isn't then lights on a bull bar is a good idea and a hookup can just be added to the battery terminals.
If I didn't have factory lights,but I do, there must be a line you can tap into or some sort of fuse or relay. HTH
Yes, this helps. Thank you very much for answering. I'll poke around this week to see what I can find.
Cheers,
John
Check behind the valance near the rad support on either side for connectors with tan/orange and black wires. Then check behind the radio bezel for an unused connector with TN/OR, LB/BK, LB/RD and BK wires.
If you have those 3 connectors, then your truck should be prewired. To set it up exactly like a stocker, you would need the radio bezel with the cutout, the switch and the foglamps plus a relay in the underhood relay box.
If your truck is not prewired, it is always possible to add an accessory switch, fuses, relay and lamps of your choice. Some aftermarket kits, like those from KC Hi-Lites, have everything you need including instructions.
Excellent information...that's just what I needed. Thanks, bud.
My '04 appears to be wired even though it came without fogs. There are pigtails behind the valences, and I would assume there is one behind the radio bezel as well. I eBay'ed a bezel with the 4x4 switch, both 12v jacks, and the fog light switch a few days ago. I'll let you know how it goes.
Thanks, ej, I'm looking forward to hearing the results. I'm not real experienced with working on full-size vehicles but I've torn up enough RC trucks to think I might be able to handle it.
Cheers,
John
08 ranger fog lamps
ok a new guy here. 08 XLT Supercab No stock fog lamps. Now I have a 06 Fusion and it has fogs and the switch is on the reg. light switch. I know a question that has already been asked here I'm sure. I have looked for the pigtail for the fog lights behind the bumper. I have found wiring on both sides near the
fog light bezels in the bumper, but there are wires coming from those and going to the brakes. Also I have found wiring on each side of the radiator witch are plugged into a small box with "made in Canada" printed on them. I thought I could just get new relay, main light switch, fuse and plug them in and be good to go. Am I wrong? a little assistance please. sorry for the old question asked again. great to be here! :dunno:
