wiring diagram needed
fordblueblood
I am trying to find a decent wiring diagram for an 85 Bronco II. My wires going from the engine compartment to the rear of the truck were ripped out when a loose wire in the harness got wrapped around the front drive shaft. I have a Haynes manual and the diagram in it is useless as well as the ones on autozone. If anybody has or knows where I can locate a better one let me know ASAP.
Your local library should have manuals on your truck. The ones at mine are detailed.
Go pick up a chiltons... they have pretty good wiring diag...
Might give you a headache but it will get the job done!
Depending on where you live, you might find a Pull A Part and pull a complete harness from the firewall to the rear lights. I just did my '84 and it was not all that bad. Also, check out Ebay for a factory EVLP book. (I think I got it correct, electronic, emisson, vacuum). I purchased one of these as well and it is a great resource.
