Buba Ganushe
- May 24, 2010
- Automatic
I know this has been asked many times but any suggestions on the spark plug wires i should/shouldn't get. Its a 99 btw thanks
I always buy the lifetime warranty wires from whatever parts house I'm going to at the time.
In real life wires is just wires! Until you get your engine over six grand any wire will suffice. However at high (really high) RPM the spark needed will have to come from another source besides the stock system. THAT spark may need better more secure wires to travel thru.
So for now just save as much money as you can and go with the NAPA or O'Reily or whatever house brand with a lifetime warranty and you cannot go wrong.
Big JIm![]()
Well, keep in mind with Ford's EDIS, the plugs fire every revolution of the crank, not every 2 revolutions of the crank as with a conventional ignition system. So, at 3K RPMs they are firing the equivalent of 6K RPMs.
BUT one of the firings is under pressure and the other is simply a nominal firing with little if any pressure.
Big Jim![]()
