wire tap
apmurphy
Norfolk, Massachusetts
i've spent hours browsing the tech section and searching threds but can't find which dash wire leads to the high beams. i want to connect my kc's to my highbeam switch for convenience but the tech page doesn't have later model wiring info. or should i just tap the kc relay into the highbeam relay? any help is appreciated
Your relay for your KC's is under the hood?
If so just use the highbeam power wire at the headlight as your trigger source for the KC relay. You can find that with a simple test light.
Should be able to pick up a cheap one at any auto parts store.
