marcuspur
- May 28, 2010
alright im takin out the wire harness and replacing it and sensors because i cant seem to find out why my truck wont start im not getting spark im also taking the intake off because its easyer to get to the injector wires and im goin to port it as good as i can
here she is be for i started
[/IMG]
alright start by unbolting the computer witch is located under the kick pannle on the passinger side there is also a ground you will need to unbolt
[/IMG]
ill be making this look alot better when i put in the other harness this rat nest of wires is just plan ugly
[/IMG]
[/IMG]
next i took off the intake box and toob the box has 3 or 4 bolts on the under side of the finder i also took out the radiator so i could paint a few rust spots.make sure to take out the battery or atleast unhook it!
theres a ground wire under the air box on the finder
[/IMG]
i had another ground on the back passinger side of the intake manifold witch was wired because it was orange and was just a striped wire no end on it
[/IMG]
also one more ground on the side of the coil
[/IMG]
theres a power wire on the starter soleniod the yellow one
[/IMG]
now fallow the wires and unplug everything thats conected and pull it to the passenger side
[/IMG]
it helps to take off the intake manifold to get the injector plugs i beleve it was 6 bolts
take off the vacuum hose's
[/IMG]
[/IMG]
and take off the thottle cable
[/IMG]
now just pull it off and unpluge the injector wires mine where burned or melted some how
[/IMG]
be sure to cuver the holes for the intake you dont want anything to drop in there
[/IMG]
now just pull it threw the fire wall you will have to get the rubber gromet loose first and as your pulling it make sure it doesnt get stuck on any thing
[/IMG]
