wiper relay click
91wannabe
bloomington, il
so this kinda sucks cuz i have no wipers. When i try to turn on my wipers, all i hear is the relay click, and the faster the speed the faster the relay click. could it be a stuck relay?:icon_confused: i need help FAST!!!
that actually sounds like normal operation of the delay wiper module to me.
sounds like theres an open circuit between the module and your wiper motor....
Thank you, also last saturday, i got them to work, but very slowly, they seemed to only work if i pushed the wash button. and were almost like sticking halfway up the windsheild then they would free up and get stuck again on the way down. Still the module?
My wipers did that after a swaped my engine/ecu/harness.
Turned out to be a bad ground for the wiper motor.
Just run a wire from one of the bolts ,that hold the motor assembly together, straight to the battery. If they work, run a wire from the motor to the body.
thanx guys, ive been meaning to try those but its been to dang cold out. im hoping to get it figured out over the weekend. Thanx again for all the suggestions, keep them coming if you can think of any more.
wipers
mine did that to, also ran on high only. not the motor, it was the wiper governor.
