Ok i'm a little stuck here! I found a junkyard valve body on Saturday and it "appeared" to be in good shape. I swapped it out and put everything back together and honest to god I thought I fixed it because it wasn't hesitating before going into 1st gear anymore. Boy was I wrong, I only traded one problem for another. Now it doesn't hesitate going into 1st gear, but it does wind out 1st gear until like 6k rpms before shifting to 2nd. I took it right out on a straight flat road with no traffic and got it up into 3rd gear and it cruises fine, but if you slam down on the throttle it starts to slip! Now if I start out from a dead stop and hold the throttle wide open it'll shift straight through the gears without hesitation. I did a stall test and everything was within normal range. I pulled live sensor data to check the speed sensor because i've heard of people having trans problems due to sensors and that checked out fine. One thing though, the TPS is definitely out of range, it's only reading 18 to 93 percent with no dead spots, but I can't see how that can effect it in any way. Basically is there any way that any sensors at all can actually cause slippage? It's weird how it doesn't slip from a dead stop but it does when i'm at higher speeds on the road. It almost seems like i've traded one valve body problem for another which might be due to my negligence to test all of the solenoids when it was out of the vehicle. Would anyone happen to know where I can get pinouts for the harness on the transmission so that I can test the impedance of the solenoids without ripping off the side cover again? Alldata doesn't seem to be that descriptive in that area. Any input would be greatly appreciated because i'd rather try every test in the book before resorting to replacing the transmission.
