Windstar Question?!?!?
Well I got REAL lucky with this abomination of a mini-van! One of my local u-pull-it yards was having one of their transmission sales a week ago and what do you know, I go up there and they JUST get in a 98 windstar that's wrecked up pretty bad in the front end. At first I was worried because the thing had over 200k on the odometer, but the trans was way cleaner than the motor, so I took a chance on it. I ended up having to drop the subframe with the van on jackstands and it was a sight to see! I had one cherry picker supporting the motor, another cherry picker for raising up the replacement transmission, a floor jack on the passenger side of the transmission for support, and another floor jack keeping the rear passenger side of the subframe supported so that I could get away with not having to remove the exhaust. The job took 7-8 hours with a food break somewhere in the middle. For some reason it seemed to me that alot of the process seemed VERY similar to replacing the tranny on a Buick LeSabre, even the shape of the transmission looked almost the same. Even though the transmission shifts smooth and everything I am actually contemplating getting rid of the thing after all of the problems with them that I have been reading about lately. It's pretty bad when a mini van with only 65k miles has a transmission fail out of nowhere. My aerostar which I just recently retired to the junkyard had 214k on the odometer and according to the original owner who I purchased it from it had never had any work done to the transmission at all. If it wasn't for the body rotting out from underneath it I would have had no reason to get rid of it and even though they are known for weak transmissions I would much rather swap out a transmission in an aerostar than a windstar. It seems almost as if the car companies are discontinuing the stuff that's easy to work on only so that they can come out with something that's almost impossible to repair.
Windstars have HORRIBLE trannys in them.
I don't know what the hell Ford was thinking when they did that.
