Window Leaks
KY4X4Ranger
Any one ever had the rear window leak on an 02ish Ranger extended cab? I just got one yesterday and noticed that the headliner is soaked on the driver's side.
I just bought a 2000 Ranger extended cab and noticed water on the inside of the rear window. I checked out the window on the outside and it seems to be sealed well. The only place I think it could leak from would maybe be the sliding rear window. Is there a way to better secure the slidng rear window?
3rd break light is the most common just take it out lay on a thin bead of silicone and reassemble.
$10 says you have a satellite antenna installed coming thru your third break light. The foam factory seal on that light will give over time due to that wire....I've tried butyl (aka dum-dum) and still no luck. I'm probably just gonna silicone that bastard into place
My '02 leaks. I have had it checked and the seal around the top of the window on the driver side is broken. It looks great from the outside, but i had it smoke tested at the local glass shop and we found it. The fix for me is to have the window resealed. About $70 was my quote.
