Window issues
redneksoldier
Solid Axle Swap
Tulsa, OK
Having an issue with the window jamming up. It will roll up about half-way and then it cocks toward the front and gets jammed. You can easily dislodge it by hand or by rolling the window back down, and if you hold the window straight back toward the rear while rolling it up, it does just fine. Seems like the problem is the liner inside the window track. I adjusted the track inward as far as it will go, but no change. Still lots of play and gets jammed. Anyone know where to buy new liners for the window tracks??? Can't find it in the places where I usually buy everything.
i have the same issue, and a friend says its a broken plastic clip. i havent looked into it yet, but will before too long
Nylon bushings on the window actuators need replace. My 64 Falcon van used to go through a set about every 2 years. Should be easy to get replacements from the stealership.
You know, I saw those bushings on the center of the regulator. I thought "If that fit a little tighter, I wouldn't be having this issue" but it looked like it was made that way so I just dismissed it. Going to look into that today. Thanks for the heads up!
