Winch cradle
The Jester Race
Sacramento, Kalifornia
I'm going to build a winch cradle for my new toy, a Smittybilt XRC8. Anyways I'm looking for some cradle ideas. What material? How thick of material? My dad says 3/16th inch minimum for material thickness. I was thinking maybe some 6061 T6 aluminum.
What do you think? Thoughts, Ideas, Advice?
-Jester
I got the XRC10 and i used 1/4". I wouldn't go less than 1/4", its holding a lot of weight over a wide span of flat steel. I don't recommend aluminum, not an area to save weight.
yea i would go with 1/4 for the place an use steel.. thats what mine is made out of for the same winch
My plan is to use 1/4" C channel welded inside the frame rails. I wouldn't go any thinner steel than that and definitely not aluminum. You could also do a receiver mount winch and put a receiver hitch on the front of the truck.
....that is a cradle mounted winch.
Maybe I should post a picture.
Winch Cradle:
Winch cradle
So it sounds like the aluminum is a no go.
-Jester
Ha, my bad. Too many names for stuff.
Yeah I'd stay away from Alum and go with at least 1/4 or even 5/16 plate.
No, its my fault, I should of specified. I didn't realize that people called winch plates cradles too.
But its all good.
Cheers and beers
-Jester
