cp2295
- Jul 25, 2013
- Washougal, wa
- My credo
- If you ain't first you're last
Doing the 3.0 to 4.0 swap will this wiring part work out when plugging in the 4.0s harness in? It plugs in but idk if the stuff behind it is different on a 4.0. Also the air cleaner tube, I was wondering since the 3.0s tube plugs into the 4.0s throttle body (I noticed at the mafs side however it's bigger) if it will work fine? I also notice both the iat and the mafs plug from the 3.0 plug into the 4.0, but idk if the sensors are different between the two. Any clarification would be much appreciated thanks!
I have the 4.0s tube and mafs bracket plus the top where it clicks down over the air filter, I just don't have the mafs and I would like to save some cash as I see the 3.0 mafs won't go into the 4.0s bracket. But I figured they're both reading air flow so what the hell?
Any another question, how do I get the throttle cable off the gas pedal and thru the firewall? I haven't looked yet but if anyone's done It that'd be cool if you had any pointers. To me it doesn't look as though I can use the 3.0 cable on the 4.0 TB.
