Will they fit????
Lifted-R4nger
Hey i em looking into buying some Nitto Mud Grapplers 33x13.5 and was wondering if you think they will fit my 15x8 rims??? and if they will rub when i turn, i have a 4''suspension lift and a 3'' body lift.
Thanks
you should be fine. with the skinier rims it might make the centers wear slightly faster, but probably not enough to really notice.
I have 33x12.50 on 8 inch rims and they run jsut fun. I rub a little cuz I am bone stock.
Thanks
They will work but you will have to figure out the best air pressure to run since the tires really are recommended to use 10 inch rims. The center WILL wear out fast with 8 inch rims. That is why you need to watch that air pressure.
The best way is to get some big pieces of large flat cardboard (white is best)and run over it with your air pressure set just at or just below the manufacturer's recommended air pressure for that tire. Look at how the tire pattern looks to you. If you see the center tread is darker the the outer tread adjust the air pressure down a bit. If you see the outer trad is darker then add some air to make it look even all around. You should be able to see all the tread looks even. This is how I did my Wrangler when I had some wide tires on 8 inch rims. I never had a problem with them wearing out the center. Two of my buddies did not care how their tires were and they had to replace them after less then two years...haaaaaaaa!! I kept telling them to take the time to adjust the air pressure..but...NO!!! Too lazy!!! ....lol
