In the tech article for the swap it mentions below that 'i can buy them from an off road shop'
Where can I find/order these from?
Also, the spring perchs are fine because I was going to flip my rear to lower it anyways, is this correct?
http://www.therangerstation.com/tech_library/Explorer8_8.html
Shock Mounts:
The Explorer shocks mount in a different location than those on a Ranger.
You'll have to have new shock mounts welded on and can buy them from an off-road shop. I had the shock mounts welded on at 40-degrees. The mounts were welded on with a 3-3/4 inch space between them and the spring pads.
________
vaporizer affiliates
Shock Mounts:
________
