will not start in the mornings
eddie.lrogers
ok im dumb founded on this one 4 bangger will not start in the mornings if it set over night and if the weather is below 80 that night have replaced fuel pump, filter, filler hose i have fuel presure at the fuel rail. this is driving me crazy because it will start when i get home from work but i drive 48 miles oneway to work everyday and my other truck only gets 11 mpg no check engine light on or anything is there a sensor that could be playing games with me
Does it turn over? If yes, then check fuel relay. If not, check starter relay.
Do you hear the pumps kick on? If you arent sure, remove the gas cap and listen for buzzing. If not, check the fuel pump relay (green). Even if it clicks on, it might still be no good. With the key on, check to make sure that the same voltage going in is the same voltage leaving it.
If thats not the case and the connector looks OK, get a new relay.
