Will not go into gear
robbo
So my truck is '01 3.0 manual. If I am not moving it's sometimes hard to get it into gear, but other times it's not to bad. But if the truck is moving a little I can get it into gear, sometimes it takes a little jamming. But other times it works just fine. Also at times it makes some loud rattling noise when I push in the clutch. I figure new clutch and slave. Just want some other opinions before I blow another weekend working on the Ford. By the way it has 151,000 miles on it if that helps, and I don't think the clutch was ever replaced before I got it.
Thanks
Robby
I'm having the same issue. Did you ever figure this out? Was it your slave cylinder?
The poster of this thread hasn't been here in 8 years... don't hold to tight that he will reply.
I suggest going to the transmission forum and describing your specific symptoms and ask your own question, Most folks here are very willing to offer help.
