will jeep springs fit
If you can, might as well, from the sounds of it you might have to, plus your ranger will look so much better in the end and do what you want it to do.
got ya... what r ur thoughts on this swap ?
Honestly I would lower the rear down to a more reasonable height (and if that isn't what you want, then go wider using full-width axles from a F-150).
I have about 6-8" of lift and i am going to lower my truck down. Its no fun when you get a feeling that your about roll over climbing around on stuff. Ill go with 4" of lift and lots of cutting. I cut the hell out of my rear fenders. I have the front fenders off now to do the same.
yea there is no point in doing all that lift when your not running that big of a tire...low COG is the way to go
well i picked up the D44 yesterday.... gears are not what i hoped for but i will just need to get a new set for it... i got everything off of it but the r-arm bracket..... i will poast a pic soon.......
