will it fit?
meanasposible
hey iv got a bone stock 1994 ford ranger xlt 4x4 and im wondering 2 things
will 1980 bronco 2 rims fit on my hubs?
and with my stock ride will 33s fit without rubbing?
and if not how mutch of a body lift will i need?
hmm that helps i just found a set of bronco2 33 for 50$ and trying to figure out if its worth it....
How's the tread? If the treads good pick them up! 50 dollars for a set (or each) is a steal either way.
Don't forget to factor in the cost of a lift. Lifts get expensive.
the tread is mint like 80% front and 70% back
in not going to do a suspention lift cuzz i rly dont wana flip my truck so im thinking a 2-3 inch body lift
these cost anywere from 2-4 hundred am i corect?
o and its 50$ for the set
yea not a good idea my welds look like bird poo
is there a preferd brand of body lifts that are more durable or are stronger?
were the hub diameters different between the dana 28 and the 35? i know the BII wheels fit on the front of my 1994 2wd, but im not sure if the center hole is big enough for the 35 hub? BII wheels are 6" wide and the have 3.75" backspacing so they give your front end a narrower wheel base. ive got 30" MTs on my 94 with leveling coils and they almost rub when on the bump stops.
this page has picks of mine with the 30s and with the BII wheels so you can see the narrowness im talking about. http://www.therangerstation.com/forums/showthread.php?t=37621&page=27
ok so i when to look at the tires today and i was miss informed
the tires are from a 1987 fullsized bronco
i know you said that tey wouldent fit johnny o but i wana check cuzz they are mega sick
deep dish and crome and i measured them and on my ranger if the bolt patern fit they would sit bout a half an inch out of the wheel wells
ranger is 5x4.5.............full size is 5x 5.5, definitely will not fit without adapters
is it worth it to buy adapters?
how mutch are they?
are they garbage?
Too much.
Just keep your eye's out for some Ranger rims that will fit. At that price, you could buy them, separate them, sell the rims, then wait until you see a set of nice 5-4.5 rims for your Ranger.
