actbubba
Will a computer/ECM from a 92 Explorer 4.0 automatic 4x4 work in my 93 Ranger 4.0 4x4 manual?
while you can freely change computers (manual for manual or auto for auto)
on 1990-1992 4.0's, 1993 is an "orphan year", ONLY a 1994 computer is certain to work right.
the 1993's use DIFFERENT injectors and are looking for the signals from TWO HEGO sensors (on in each down pipe leg of the Y-pipe)
There are some 1993 computers that wouldn't work (Cali emmissions)
SOME 1994 computers would work but you'd have to find a Non-SEFI 1994 computer.
The two best computer to use would probably be an "ANY1"
(these are found in 1993 M/T Explorers)
AD
How did the 93s get different injectors. I thought all 4.0s were 19#s
93 and up are anticlog too.warrantee didn't cover cleaning the 93 and up.1993-up were 19#.
However the 1990-1992 use the same 14# injectors used on 2.9's
and 3.8liter EFI engines.
DO NOT get specifically hung-up on flow rate, ANY of the
injectors used are capable of flowing far more fuel than
the engine can use, what IS VERY IMPORTANT is making
sure that the computer is used with the injectors it is
calibrated for.
There's Right & Wrong.
It's a case of "different", not necissarily better.
AD
