will a 4x4 specific limited slip diff fit in an 86 2wd?
JB3
Im trying to find ways to make my 86 auto 2wd slightly more winter capable. Are there any bronco2 or ranger diffs with LSD that might fit in a 2wd?
There's no such thing as a "4x4 specific" LSD. If you have a 7.5" rear axle, then any LSD for a 7.5" will fit. If you have an 8.8" axle, then any LSD for an 8.8 will fit. It doesn't matter if your truck is 2wd or 4wd.
If you're looking for a used axle in a junkyard, then any Ranger axle will bolt in and work. It doesn't matter if the axle came out of a 2wd or 4wd truck; they both used the same rear axles. LSDs were available in both 2wd and 4wd. Just make sure you get the gear ratio you want.
Ok excellent, i didnt know if there were any frame differences that made a leaf spring mounting difference on the diff housing itself. If run into this with some GM stuff.
Next questions, can i use a diff from a much later ranger? Like say a 95 or newer? Any year ranger will work on ag en1?
Are there external physical differences in the housing i can look for to identify a potential LSD?
Any Ranger rear axle should work. Read the stickies for U-joint information, it will save you some headache. Technically GenIII+ is a slightly wider axle, but I'm told it's not noticeable. We're talking fractions of an inch per side...
