Will 32's be alright
MikeyFord3
Greenwich, NJ
I have a 1995 4 banger 4x4 truck i have 31's with just a leveling kit now and its runs great the gear ratio is 4.10
if i get 32x11.50 do you think i will need re-gearing and how much suspension lift would i need i was thinking like 4 inch suspension and maybe 1 inch body?
there is a tire fitment guide in the tech library at the bottom
Well, since your only going up about an inch in tries size, you will lose a small amount of power and your RPM's will be a tad lower at any given speed. I imagine the truck is somewhat sluggish with 31's on it, it'll be a little bit worse with 32's.
But, 1 inch is not enough to concern ME....(if it were my truck)
its not that sluggish with 31's it moves good enough for me
but thanks
but thanks
Allright, in that case, just consider that it will be slightly slower with 32's, as they are harder for the engine to turn.:icon_thumby:
I really don't think you'll notice to much. Go ahead and do it. I'm, planning on running 31's with my 4cyl & 4.10's.
4.10's and 31's are a good combo, I'm running 3000rpm at 55mph in 4th gear, just about right.
I can't imagine 32's being much worse, plus they would probably fit stock on a '95
