Will 17x9 Cobra R rims fit on 87 ranger?
Wigifries
Sorry if this a repost, but i like the looks of Cobra R's and i was just wondering if they will fit on my 1987 regular cab ranger without spacers, or if i need to get some sort of spacer?? I've heard that mustangs and rangers have same bolt pattern 5x4.25 but just need reassurance! Any Feedback Would Be Greatly Appreciated!! Thanks
Bolt spacing is 5x4.5 for bot Mustang and Ranger.
Sometimes they fit, sometimes no without a spacer. That is honestly the best answer I can give you. I just went through this myself. I ended up getting rims from:
http://www.coyswheel.com/
I should have them by the end of the week.
I called a few Mustang aftermarket companies and none of them could answer my questions with confidence. I was told that I could order one rim and see if it fits.
I know people here have had them fit while others have had to either use a spacer or not put the center caps on.
James
Thanks man for the Info! It helps a lot! I will be sure to check out the website!
