Wiggly Truck Issue
Ranger Kip
⭐Supporting Member
Wellsboro
PA - USA
Vehicle
Drive
Confused and Intolerant
My truck is very wiggly and jiggly, it also hops around. Any thoughts? The rear shocks are new, the frame is not bending/crossmembers are not shifting, and the axle is firmly installed.
It seems all of the wiggle is coming from the tires having big sidewalls.
It almost feels too unsafe to drive over 45 with how loose it feels (wiggly).
My steering is solid, tires are new, front stabilizers are good, and rear shocks and shackles are new.
(Sorry if it's hard to see in video, but I'm pushing on the rear of the truck and the front pivots to a wiggle).
Generally speaking, those tires do not have big sidewalls. What air pressure are you running?
Do you have anti-sway bars installed? Are the spring eye bushings and shackle bushings and bolts good?
These trucks, in stock configuration, are not as "tight" as a sports car. That's just how trucks are. I'm not saying there isn't anything wrong. There may be. But, if this is your first truck, your expectations may be a little bit too high and you may need to get used to it.
It kinda looks like you did a torsion bar crank...
Wiggly Truck Issue
If you did... that really changes the ride quality. Not that it makes it stiffer... but that you cranked all the rebound out of the front suspension.
Withall the frame repairs... front end work... etc... have you had it on an alignment rack to dial it back in?
What shocks did you use? I used to call my Choptop my big spring toy because it was like driving a foam block on the end of an antenna.
Then I started chasing vibrations and upgrading things. Couldn’t get the shocks I was using on the rear so I got some KYBs and the ride quality immediately improved. That got me looking at other shocks and I ended up going Rough Country N3 all around. I don’t think I’ll ever use anything less than a KYB for a shock again on anything.
Mind you my Choptop sits on 35x12.50-15 tires run at 15 psi. If you want to talk sidewall flex, I have it, lol.
Did anything change with the new tires?
Was it doing it with the old tires?
