Why is the coolant gauge always perfectly in the center on my ‘99? Is It a dummy gauge?
I support common sense
Forum Member
N/A
TN - USA
Vehicle
Drive
2”
15”
I have a ‘99 Ford Ranger and the coolant gauge is always centered maybe closer to cold on the gauge. You start it, it warms up and then it rises to the center. Shouldn’t it be fluctuating? You climb a hill and it should get warmer, right?
I’ve got similar questions with the voltage gauge too, but I guess it normally sits around 14.
Is there anyway to make this coolant gauge more accurate?
I know some temp gauges are what's called idiot gauges. They go to roughly center with the key on then jump to the top if it overheats. No in-between. Seems stupid to me. It should've been cheaper and easier to make them work like you suggested.
^this. It is linear until it gets to the normal operating mark, they it stays there until it starts to get into the danger zone. Im not sure how the ones on our trucks operate but i know the newer fords are like that
The coolant gauge is not a dummy gauge. Oil pressure is.
Sounds like a properly functioning thermostat and cooling system to me.
A purely mechanical old-school temperature gauge is going to fluctuate some like you are thinking, but on a properly working system even that is going to be minimal.
By 98 manufacturers were building vehicles so that the gauges would dumb it down some to reduce customer.complaints and questions. Easier/cheaper for them to dumb things down than educate the masses.
Some of the gauges use circuits that somewhat stabilize the readings so that the needle doesn't move with every minor function in actual readings. Fuel gauge with its anti slosh circuit is a perfect example of this. Other gauges became a fancy idiot light, like the oil pressure gauge. Pressure is good is stays solid in the middle, pressure goes out of range, high or low it moves, but people complained about having a warning light instead of a gauge. To my knowledge coolant temp still pretty much reports true unless the sensor is bad. The temperature at the sensor location just remains that stable unless there is a problem with the cooling system.
Generally the cooling systems are over built on a properly running engine that is still within stock parameters. As long as it's maintained and thermostat is function properly it will hold a steady system temperature. If the thermostat is stuck closed it will warm up like normal and keep climbing, overheating relatively quickly. If a thermostat is stuck open it will take much longer to warm up, if it ever does, because the coolant isn't staying in the block long enough to build the heat. If stuck open and being worked hard or driven long enough it'll eventually overheat because the coolant isn't staying in the radiator long enough to cool off.
The F-250 in my sig is a perfect example of the latter. From the time my dad bought it around 20 years ago the coolant temp barely moved up into the normal range. It always bugged me but it never overheated. Last year I finally pulled the system down for new coolant and hoses, and new Motorcraft thermostat while I was in there. Not only was the thermostat installed lower temp than stock, it was also stuck open. I can't say exactly when it failed, but the cooling system in that thing was so overbuilt that we would rarely work it hard enough to really build the system temperature into the normal range, and never enough to overheat it.
Pretty sure the temp gauge is dampened in newer vehicles
I know that there was a point that the oil pressure went from a real gauge to an on/off switch. There’s a few write ups and stuff on here about fixing that with an older sensor
Temperature gauge should track with temperature. It is not a dummy gauge. You can check it, crudely, by disconnecting the wire from the sensor. The needle should go all the way to bottom, I believe. Then, short the wire to ground and the needle should max out at the top. Temperature should stay fairly steady most of the time, especially in cooler weather. Hot days with hard highway druving and hills, you should see it swing 10-20 degrees or so as the thermostat and fan clutch cycle.
Oil pressure is usually a dummy gauge. Actually, the gauge is fine. But it is served by a switch instead if a pressure sensor. So, when minimum pressure us reached, the gauge reads normal pressure.
Volt meter is really sensing voltage. You should see it read differently depending on operatung conditions. Immediately after startung the engune, it should read between 14-14.5 volts, roughly. After a few minutes, when the battery is replenished from its engine startung duties, the voltage sgould come down more between 13.5 and 14 volts for normal operation. During periods of really heavy loads, like winter with headlights on, heater blower on high, engine running, stereo playing, etc. You might see it dip a little bit lower. But in a healthy system, it should still be close to 13.5volts.
For the volt gauge, the oil pressure gause, and the temperature gauge, the center is normal operating range. On mine, for 20 years, I ran a 180. With a 180, it points about a third of the way up. I now have a 160 for various reasons, and it points between centered between the two lines on the bottom.
My truck no longer has the EGR or EVAP, and the converter no longer converts. Smells like an old school hotrod when running. With a 180, I get all kinds of codes when I scan it. With a 160, I get zero codes. It's because the temperature is too low to allow the computer to make the switch from Open Loop to Closed Loop. In closed loop, the o2 sensors are ignored. Runs Open Loop full time. Thus no codes. Runs frikkin sweet too!
Yeah, no smog checks where I live. All the smog stuff is removed from my 2004 Lightning as well. On both trucks ,the CEL bulb burned out years ago. I ain't replacing them.
all good points, but I work my truck hard. It could be 100 degrees pulling 3500 pounds up a steep hill in first gear and that stupid little water temp guage sits happily in the center. I really don’t care what it reads when I’m driving it to town for work, but when I’m hauling mowers I’d like to know if I’m working it too hard. Maybe the coolant system is way overbuilt and it’s just that good at keeping it cool. I really don’t know.
I was reading somewhere about the sender, and I recall hearing something about the resistance curve having a flat line or something where the operating range is. In other words, after it reaches operating temp it keeps voltage to the guage the same during a large range of temps. Once it exceeds that it’ll boost the current. I don’t completely understand this, but if it’s true then I should be able to get a different sender that’s got a curved line. I keep imagining it like a torque curve and how they are different for semi trucks vs city buses.
For future reference, anyone here who builds a vehicle or starts a company that does, I like to see real data in real time. Don’t care if it’s a little Honda fit or an F450, I like real information. Just in case anyone here begins manufacturing vehicles😉. That goes for you too Ford.
Could always get a mechanical temp gauge and install it.
People are dumb. Manufacturers are catering to that. Used to be you walked around your vehicle before getting in to make sure you didn’t have a flat tire or a leak. Like preflighting a plane. Now you need alarms and lights to show you have a flat tire because people don’t have the common sense to pay attention to anything but their phones.
I rerouted my temperature signal to an aftermarket gauge pod wuth a gauge that has actual temperature numbers on it. I don't see any "flat spot" to the readings. It should be pretty linear. As temperature changes a degree, the resistance os the sender chages x ohms, across the scale.
I also replaced my oil pressure switch to a pressure sensor and rputed that to an aftermarket pressure gauge.
I like real data, too.
'95 gauge will definitely climb under hottest conditions (stationary, A/C, 90* out). So, even if they dummied the gauge at some point, you can probably slot an earlier insert into an '03-down cluster and get it back.
That said, just like every time coolant temp comes up in discussion, I wouldn't assume you're getting hot doing whatever unless you get out and point a temp gun at the engine to verify.
That right there is important. Without actual data, it's all guesswork. And to see what thevgauge should be reading, you must point the tempetature gun right at the base of the sender. Anywhere else will be inaccurate.
Not a bad idea, I may give that a try.
Thank you, this is what I needed to know. That confirms it’s not the sender, assuming yours is a post ‘98. I’ve got a cluster of analog gauges on order now. One for REAL oil pressure, one for transmission temp, and another for engine temp. I also threw in a vacuum gauge because why not. Also got a voltage meter that has numbers on it. Whoever came up with the idea we should add gauges with no numbers was an idiot.
quick question, where do y’all normally put your transmission temperature gauges? I was thinking about the line going into the aftermarket cooler, but I was told the pan is the best spot, I just didn’t want to drill.
