BigPimpin91
- Oct 3, 2009
After clearing up the issue with ATF in my clutch system, I got a new master, slave and lines.
Gravity bleed it.
Go to slide the trans in.
I have to depress the clutch to pull the throw out bearing away from the shift forks to slide it in, and for no apparent reason it just starts POURING DOT3.
When you get a new slave cylinder is there some kind of special thing you got to do to it?
I put the bearing on the shaft and the rubber gasket in the side where the clutch line goes in, I thought that was it?
Gravity bleed it.
