exbass94
- Aug 6, 2007
- Age
- 37
- Guilford, CT
- Automatic
My truck is only 4 or 5 years old and has only 28k miles. A year or two ago I had the rear output seal on the transfer case replaced under warranty, and last year I had the rear pinion seal replaced. The other night I thought I smelled something like gear oil, so today I go and investigate. The front pinion seal is leaking. The diff is still full of oil, but it's apparently leaking enough that it left a small quarter-size spot on the driveway, and it flung gear oil onto engine oil pan and exhaust, which is what caused the smell.
And to top it off, it looks like the transfer case seal is leaking AGAIN. It is also still full of fluid, but it was pretty damp underneath the seal, and there was some fluid that was flung onto the underside of the cab. Could it just be the recent cold weather is making the seals shrink or something? I'm kinda hoping it won't get any worse until spring and it will magically fix itself when the weather is warmer.
