DennisF
- Jul 2, 2008
- Automatic
Why are my rotors and pads wearing only in the centers. It looks like I'm only getting about 60% of the potential braking, since the wear is occurring only in the centers while the inner and outer edges of the rotors are building rust. Please note in second picture that you can see the lower friction portion of the pad covering the inner ring of corrosion on the rotor. In the third picture you can compare/contrast the actual mating pad with the rotor surface and see that the friction portion of the pad covers significantly more of the rotor than the area of significant wear is indicating. It seems to me that since pad pressure is applied to all but the outer 1/4" and the inner 3/8" of the rotor, the rotor should display even wear throughout that portion of the surface.
Outside Surface
Outside surface with pads in place
Outside surface with view of the mated pad
Inside surface of the rotor - similar wear pattern
These rotors and pads were new in August of 2010. They have approximately 6500 miles. They are Wagner BD125469 rotors and Wagner Thermo Quiet QC652 pads. The OEM rotors that these replaced exhibited a similar wear pattern. The OEMs had approximately 96,000 miles. The caliper pistons seem to be moving freely, and the guide pins seem to be moving freely.
This is a 1998 Extra Cab, 2WD, 4.0L, with automatic trans.
I am baffled!
Thanks for your thoughts
DennisF
Outside Surface
I am baffled!
DennisF
