compleckz
its not hard, and the starter fluid method does work, u jsut have to make sure as soon as the bead seats to hook the compressor up to shot in air to extinguish the flames that will still be burnin inside the tire....
well i got the beads broken pretty easy.. i lubed all around the lips and let it set for 5 mins and they both came off wicked easy (before lube they wouldn't budge with me jumping up and down on it)..
then i got front lip off the front of the rim by prying it up with one bar, then sticking another bar in a lug hole and pivoting the pry bar around that bar, while standing on the rim, came off just as easy as doing it on a machine...
but i cant seem to get the rear lip off, tried the same trick i did before and the rim just keeps slipping on the floor (before the tire must have been giving it the traction i needed, weird tire=traction?), i need to try and find a rubber mat or something to work on.. to be honest diane, i'm surprised. (family guy reference.)
anyways it seems spoons would be very useful in REMOVING tires, but as junkie + others have said, you can prolly just step on them lubed, to install.. and as long as everything is lubed up, i dont see any problem using spoons.. i just did it with 2 bars and its exactly how tire shops do it.. i wonder if they make spoons with plastic overlays to protect aluminum rims?
