Who knows a good place to get shift control module wiring for bw 1354 T-Case?
91blueoval
I have a electronic shift bw 1354 t-case. I don't think there is any set name for it. I have heard it called the electric shift module, but also the shift control module. Basically, my harness is busted up so it has loose wire connections. This has caused my truck to have issues shifting into and out of four-wheel drive. I have cleaned the shift motor. It's good to go. I have reset the module several times. Fluid level is good. Internal t-case parts are okay, too. I have relieved torque and stress from drivelines before shifting into and out of 4-wheel drive. So eventually I got impatient and took the shift motor off, and now just manually shift the little shaft on the back of the t-case. I am long winded, but mainly I just want a new set of wires that plug into the 4 wheel drive switch, to the shift control module itself, and to the shift motor. Any help would be awesome because i want to have four wheel drive applied the normal way, and not the ghetto way where i have to get under the truck to shift it. Thank you
New from Ford = $$$$$$$$$$$$$$$
I'd get one at a junkyard. Its pretty rare for the controller module itself (and the wiring) to go bad (its usually the t-case motors that go out).
If the motor is there too, grab it for a spare (or for parts).
You didn't mention what year your truck is (I'll assume '91 from your username). Anything Ranger/Explorer/Bronco II from '83-'94 should work on yours ( if yours is newer, then look for '95&up Rangers)
Hope that helps
Thanks guys. I have thought about the salvage yards but usually the t-case stuff is picked clean. Without a doubt the module is fine, just need wires. I'll definetly check up on a local ford dealer for fresh wiring.
