- Feb 5, 2023
- Age
- 32
- Tacoma, WA
- 2.5 (4 Cylinder)
so I uploaded a video to YouTube it’s only a minute long..
I have a 98 Ford Ranger with a 2.3 harness and pcm replacing the 2.5 harness and pcm. What could be causing a not so firm upper radiator hose that’s cold when the engine is warm all the smoke out the tailpipe? Now my first thought is head gasket with coolant leak and internally although the oil isn’t milky, but the exhaust smells sweet… I have replaced both O2 sensors, new cam sensor, new crank sensor, new thermostat because the other one got plugged up when I tried to use blue devil head gasket sealer, if you can leave me your thoughts, I would appreciate it because I’m about to push the truck off a bridge
