which weld process for bed/fender work?
pjtoledo
15+ Year Member
⭐Supporting Member
Toledo Ohio
about to take on sheet metal repair. I'm wondering if MIG or TIG is best for the thin stuff.
some long welds will be needed on the rear fenders.
I'm strictly novice at MIG, mostly heavy, and haven't tried TIG yet.
which one is better for a good smooth seam that can be worked to flawless perfection? :icon_rofl:
I'm not too concerned about the bed floor, but I'd like the fenders to be decent. how does bed-liner look on the exterior? :stop:
.023 for the MIG, don't have any consumables for the TIG yet. yes, I know I'll need Argon.
Every tigged weld I've ever seen has been cleaner, but that may just be people showing off.
TIG is better, but I don’t yet own a TIG so I usually try to MIG as much as I can. Sometimes because of the situation I have to use flux core wire feed and that’s not nice for sheet metal.
Best practice... You will need to hammer and dolly the welds to normalize the heat shrinking. But that's only if you can reach the back side. I don't have any true experience though, just been reading and watching videos.
TIG would definitely be better. But MIG should be fine and has been for many years. Actually it can be done with stick or gas.
With thin materials, heat control is the key, in my opinion, regardless of which welding method. Do good layout. Make sure the pieces are lined up. Tack the seams to lock in the positioning. Then careful welding. I haven't done much thin material. So I don't know the best way to finish without warping. What I would try, would be to go back and fill in between the tacks with short stitches, alternating to different areas frequently to prevent building up heat and warping it.
Do some practice pieces and watch some "good quality" YouTube videos.
Also an air compressor and blow gun to cool the welds after a tack helps with sheet metal work, heat generated by welding is what warps the panels. It’s a lot of tack, tack, tack…
Never thought about the blowgun. Thanks.
I would MIG and it will be best as a stitch weld or tack welding every 2 inches or so to keep the heat from warping things. I would practice as well and if you can get to the back side with a piece of copper for a backer it will help the burn through. For thin stuff I err on the side of more wire speed and less voltage which has helped me with blowouts, I've done very little body work though that was meant to be presentable involving welding... sure I've tried but not in a while.
You’re welcome. It’s one of the tips I’ve picked up over the years in trying to learn better methods, came across a couple sheet metal repair videos that suggested it since you don’t always have access to the back of a panel and waiting for it to cool on its own makes an already tedious process even more so.
Side note, I’ve also learned that it’s possible to warp 1/4” steel by dumping too much heat into it at once welding. Being in a rush when you weld seems to generally result in a poor end product, take your time.
Tig is going to be the best because you have the most control. The filler is also easier to sand for whatever reason.
MIG will get you better results for a novice.
Everything I've seen when it comes to sheet metal is to jump around so as to not let the sheet metal get too hot after tacking it in place. The air nozzle isa great idea. But when it comes to welding, since I've never done it, I have more theory than experieince. All I can tell you is what those on youtube have told me is best practice.
Heck, if you know what you are doing, you can stick weld the stuff. Not that I would want to try it....
If you own a tig (and…..no offense) know how to use it, it’s better.
That’s the excuse I used to buy one, it works better.
That having been said, I still use a true MIG most of the time. Using a small solid wire with gas and spacing my welds. Being PATIENT and letting things cool works best for me.
I’m also really good at warping steel. Be patient with whatever method you choose.
TIG is better but do whatever gets the car back on the road! Generally MIG doesn't hammer back flat after welding as nicely as TIG. Do a good job keeping the heat out of the panel with MIG and as long as the bondo is less than 1/8" its going to be a perfectly acceptable repair.
yep, that's me too.
one thing I have perfected is warping. didn't matter how strong the jigs were, it warped.
