Which way does the coolant flow?
jsd
I have a 98 ranger with the 3.0l and I want to know which way the coolant flows from the radiator to the engine. essentially the inlet and outlet on the radiator.
Thanks in advance.
it travels from the thermostat housing through the upper hose to the upper inlet on the radiator and then is pulled from the lower inlet of the radiator through the lower hose into the water pump. hope that answers what you were asking?
