- Aug 6, 2007
- Age
- 49
- Berrien Springs, MI
- State - Country
- MI - USA
- Manual
- My credo
- If you can't go through it or around it, then go over it.
Which transmission do I have in my 2001 F150 5.4l 4wd?
They used the 4r70 behind the 5.4?4r70
I always thought any 4.2/4.6 had the 4R and the 5.4s got the beefy stuff (also the bigger rear end)i could be wrong. with gassers the 100 or earlier e40d was E iirc. U was diesel application. always remembered e for e.
pretty sure all the expeditions came with the bigger transmission. pickups were different depending on rating.
thus the j mod.
But i did google it and U is infact the 4r70w...and they were put in 5.4 trucks
Never mind. A little research answered my question. It will not work and wouldn’t be the cheapest option to make it work
Yeah I mean it could and my broken frame truck being a late 97 (sep 97) it likely would. But the torque converter won’t. When we were shopping torque converters it has to be a converter for a 5.4l and a 4r70w.if the thru-connector is black you can get away with it.
