94Reborn
- Apr 23, 2012
I have a Ranger that I just swapped a 1992 4.0 explorer engine into. I used a 1994 ranger 4.0 engine wiring harness, power management harness, and pcm. The truck runs, and actually runs pretty well, but the check engine light was on. I ran codes, and the codes are 15- KAM power interruption/ memory failure. And 71- which was some pcm code but my book says its for cars only.
My guess is that pcm is either bad, or because its from a 94 which should have 2 o2's and sequential injector firing, the computer just knows it doesn't belong. The weird thing is, I don't have a code for the o2 sensor, or any other codes indicating improper running conditions. Which leads me to believe the pcm is actually faulty. The pcm cal code is HAG0.
I think I want to go with a 92 explorer harness because I believe that year was still no egr, and only one o2 sensor, or a 93 explorer pcm if I install the other o2 as well right? And are both the 92 and 93 explorers MAF?
My main question though is can I still use the 94 ranger 4.0 wiring with the older 92-93 computer or will there be wiring issues? I've heard the injector harness is different for the 94 models? I'm getting slightly overwhelmed!
