Which ones Should I get
brokemechanic3000
Oneida, Wisconsin
They are different lights one is fog lights the other is driving lights, I am not sure if I want the fog lights or the driving lights. Either way I would get them from Fleet they have both Walmart only sells them online.
Are you needing to see the lines on the street better during inclement weather? Or are you just looking for more light/further distance?
That is exactly what I am thinking Junkie, Do I want better visibility in bad weather or more light. The factory headlights leave lots to be desired but are okay which would lead me to the white driving lights but better visibility in bad weather would mean the fog lights. I would like to have the the driving lights but I think I should really get the fog lights. :icon_confused:
Get both?
I have both on mine. They are set up so the fogs switch on with the lo-beams, and the driving lights with high-beams (and of course switches to control them independently as well).
Just don't use both at the same time with your headlights though (many jurisdictions prohibit more than four forward-facing lights on at once).
Thanks, I think I will get the fog lights now and then get the other ones later. I will wire the fog lights using the factory harness so no unsightly switches or wires. Then I was thinking of a bull bar with the driving lights on it.
Got them installed
I got the Fog lights and put them on
<iframe width="480" height="360" src="http://s1364.photobucket.com/user/brokemechanic3000/embed/slideshow/Fog%20light%20installation"></iframe>
I wired them into the factory harness and just had to get a couple of relays and some wire extensions to hook them up. I had a radio surround from an Explorer that had a fog light switch in it so everything hooked up with no mess. I just recieved a little burn from molten solder while laying on my back on the ground making the connections.
