Which manual locking hubs on an ‘87??
Ohio
I have been building this ranger for the past couple of years. This truck is a build consisting of several Rangers. This is my first ever build. I installed some cheap hubs a couple of months ago and they completely blew to pieces!! Anyone else ever have this happen? Any suggestions? Thank you!
  • Which manual locking hubs on an ‘87??
Were you horsing around and spinning when it happened? It's very easy for a hub to delay locking in. It's best to predict you will need it and lock the hubs in way before you need 4x4. Lots of grease and cold weather will contribute to the delay. Then they decide to lock in when you are spinning and yes they will blow apart.
I'll agree with that... these hubs can't take a whole lot of abuse like being on the throttle while the front end is off the ground... personally I have never broken a hub in the 20 years mine's been a 4x4 but things didn't get pushed to any limits until 2010 when I went turbo... but still no torque but the 5.13 gears do their job... I have a couple spare sets just in case though...
That said, do you still have the Dana 28 up front? There's zero options out there now other than stock for those, there's not much for options for the Dana 35 either but I imagine they're stronger...
If you are running a D28 its better to have the hub for a fuse to blow and help prolong the life of the axle shafts.
I would rather pop another hub on it than swap an axleshaft in the field.
Manual D28 hubs are not super easy to come by though.
I didn’t blow a hub with a 4.10 geared D-28 with a LockRight locker on 33” bias ply tires… I shattered an axle shaft. Upgraded to a D-35 and blew an axle shaft apart on that. I don’t know how you all blow apart hubs and not shafts…
AVM seems to be the brand to buy now since Warn stopped making their hubs some years ago.
(I've also seen a lot of AVM product sold under the "Rugged Ridge" brand)
I broke a lot of D28 hubs back in the day. You will get that with open diffs, wheel speed and hubs that are made out of pot metal. D35 hubs are not any better in that situation.
AVM hubs seem to be pretty well made, just do some testing to make sure they actually work before you go somewhere and actually need them. Mine would either only partially engage or disengage on their own (not sure which) but the dial would show locked in all the way but I'd have no front drive unless I unlocked and relocked them. Sometimes that would fix it for the day...sometimes 100 feet. I took them apart, cleaned & lubed everything, and so far they are OK...just beware.
