Which Gen Ranger is this mod for??
Worked on my 84, My 91 had the drivers side hose with the integrated T, but a slight change to the hard lins and the addition of a T and it would have worked there also , but I went a different route.
I used front hoses for a 1989 Chevy 2500 4x4 WITH the 8600lb GVW they worked fine on my 86 but I had to use the later calipers because 86-87 calipers are are a bit oddball. The lines also worked well when I swapped to a 95 D35 recently. the only mod that you have to do is peel the line out of a bracket that is clamped around it...
