- Nov 3, 2008
- Old Forge, Pa
Not a fan of rice but my 2" Autometer on top of the column looks sweet. Just an idea if you cant find a OEM cluster.
I can go up the steepest hill around here (MUCH steeper than anything on a freeway) at 55 with a 2.3 5 speed ranger with 3.45s, it's called using 3rd gear and the skinny pedal.So are you guys telling me that my ranger won't go faster than 45mph uphill even if a put in lower gears?Am I doomed not to be able to drive past 45 mph? Putting the engine inside another power band I always thought should make it faster.(In the low end of things not top speed. Let's not get into that discussion.)
Also I'm confused about how you can go that fast in third.My transmission has a granny first gear maybe everybody else's doesn't. Believe me when I tell you the max speed for each gear and that I'm not shifting too early because the engine hits the rev limiter every time I shift. That's just the way I use it.
I've never seen my check engine light come on when I hit the rev limiter.....odd. Maybe something else went out of specs to trip it.
James
with a '92 you have to be careful, that's the year they changed the wiring at some point to the '93 style, and I don't know what month they changed... I don't know about explorer year changes...
Getting a tachometer is now going to be my #1 priority now. I don't remember seeing a check engine light and she's always gotten awesome gas mileage so I never thought anything was wrong.
(always tought it was impossible for a stock ranger)!! I wanna say the wind helped me, but still a 100 is a 100!I'm starting to think I may have some unknown engine trouble.Getting a tachometer is now going to be my #1 priority now. I don't remember seeing a check engine light and she's always gotten awesome gas mileage so I never thought anything was wrong.
About adding a stock tach, I would probably check and ask around if those tach are accurate because I read (forgot where) that if you were going to put a tach on from another ranger/explorer, you had to make shure the tach came from the same engine you have. Can anyone confirm this?
I swapped in mine into a 2.3 from what I believe was a 3.0 and didn't have a problem.
