The biggest concern with camber adjusters with a lift is the amount of degree's that each one can adjust. There are multiple different ones ranging from under one degree to 4° degrees but the stock adjusters come with a lock tab that prevents them from being adjusted to far causing the V look. For just a leveling kit, 1- 1.5 inches a 2.75° degree camber adjuster should give you enough adjustment to get back into spec.
IF you are planing on a lift later in life then I would recommend the 4° degree adjuster allowing for more adjustment once the lift is installed other wise a 2.75° to 3.25° degree will do you just fine. In my case with my front springs sagging, which is fine for me because of height, I used the 2.75° camber adjuster to allow for the upside down V, it looked like this " ^ " in my case, to get the adjustment necessary plus have extra for when they do sag to much and I need to replace them. I've dropped a good 1.5 inches or more from stock height over the 26+ years of them being installed.
These are a simple cam style adjuster and there really isn't much tech involved in them so a major brand isn't necessary. It is basically a bushing with a off set hole drilled though it to allow for more adjustment. It uses a pinch bolt through the upper part of the knuckle to lock it into place once the adjustment is set so no complicated locking mechanism is involved. These I have found pretty cheap, price wise, on Rockauto where as my local shop charged me 35+ per side for my set. Hind sight I got screwed on pricing.
