dieseldane
Firefighter
EMT / Paramedic
TRS Banner 2012-2015
- Aug 28, 2009
- Garnett, KS
- Automatic
- My credo
- If it doesn't fit, force it!
Which RBV bellhousing will adapt the easiest to a NP435?
I am looking at adapting a NP435 into my Ranger. This has been done before, but the only way I have seen it done is to use a bellhousing for a small block Ford and make an adapter plate to bolt to the engine. What I am looking at doing, is to use a Dodge version of this transmission since it has a longer input shaft, so that I can use the bellhousing that will bolt up to my 4.0L and either drill and tap new mounting holes into the transmission case or bellhousing, or make an adapter plate that would fit between the two.
Clear as mud?
I have never had a manual transmission of a ranger out to look at it, and so I'm wondering what transmissions bellhousing you guys might think would be the easiest to do this with. If anyone could get me pictures of the different bellhousings and maybe some measusements of them, that would be awesome so that I can get a better idea of whether or not what I'm imagining can be done.
Clear as mud?
