Brian Grohgans
I know ttb alignment has been discussed thoroughly but im still struggling to find the correct the camber bushings for my truck.
Took the truck for an alignment this morning and the shop wouldn't touch it, but I did walk out with my current alignment specs
Camber: 2.5 deg left, 1.7 deg right
Caster: 4.2 deg left, 2.0 deg right
Toe: -0.12 deg left, 0.98 deg right, .086 deg total
Steer ahead (never heard of this): -0.55 deg
Truck drives nice and straight but took it in because I just finished installing a 2" spacer lift. That's the only suspension mod. 4.0L extended cab 4x4
Figured I don't need adjustable bushings cause I already have my alignment specs.
Just not sure which bushings I do need since these say not to use over 2 degrees
https://www.ingallseng.com/23180-series-ford-oe-style-camber-caster-bushings.html
Need recommendations on bushings and thoughts as to whether or not I need a DPA?
