Where is the fuel pump relay located?
Sworn
2008 FX4 Ranger
I've been having a bit of a problem with the truck. It takes several cranks to start and when it does the engine dies. It usually runs for a while and then cuts out.....I suspect it may be the fuel pump or maybe the relay. Of course, I'm going to try the simple fix first and go with the relay. So, where is it located? BTW the truck is a 88 V6 2.9 4x4. Thanks!
Passenger fenderwell, to the rear of the starter relay. The fuel pump is the higher one; EEC power relay is below and to the rear of it.
Thanks! :)
