cp2295
- Jul 25, 2013
- Washougal, wa
- My credo
- If you ain't first you're last
I bought a conversion set for my 98 4.0, and obviously I know where the oil pan, timing chain, etc gaskets go. However there's a big red O-Ring about the same thickness as the RMS. There's also a green O-ring about 1.5-2" in diameter and a copper washer the same size. There's also a small black o ring about an inch in diameter.
The big red o ring I think is for the oil filter adapter (where it meets the block) looks relatively the same size. On the fel pro tag it says:
1 bypass valve o ring
1 oil cooler o ring
1 oil filter mounting (doesn't say o ring)
Doesn't address the copper washer.
That black o ring is the same diameter as the oil filter threads but I don't see why it would go there.
I am doing a 3.0-4.0 swap, so I have little reference to work off of. The engine is from a 98 4.0 auto tranny. I have a 4.0 manual tranny. Do I still have an oil cooler line? I don't see where any cooler line would go, this engine did not come with one, so I have really no idea...
Any help is really appreciated thanks!
1 oil cooler o ring
