When did B2s get a Dana 35?
Surrey
Vancouver, Canada
The general literature on this site, such as in the tech library says the D35 was put into 1990 model years... But I seem to remember reading somewhere they started installing them in a certain month on the 1989s?
I was going to go look at a 89 B2 today, and although I dont expect it to have a D35, I sure am hoping...
i think they are D35 hybrids.....seems like i've read that on here.
even if it has a D28, you can usually find a D35 on here for around $100
Build date 11-'89 and later (this is like the last 2/3rds of the 1990 models).
My '90 Ranger has a build date of either sep or nov (cant remember) '89 and it came with a D28.
I dont think rangers came with D35 until they got a 4.0l?
My understanding was all Rangers were D28 or d28 hybrids on 2.9l and 4-cylinder engines?
the previous owner swapped in a late 89 in mine, thinking iit was a d35, but i checked the numbers and its a d28:icon_confused:
sad thing was he knew about trs, guess he didnt check
No The Hybred didn't exsist until it was introduced on Non-4.0 1993 Rangers.
So the early 1990 models had d28 then, and no 89s had a d35?
Correct
The Rangers switched over at exactly the same time the first week of December 1989 in the 1990 model run
here it is
how about a pic of the back of it, and the shaft. looks like a d28 to me but cant really tell. also there are build numbers to the right of the diff going up and down. they start with 610xxxxx, then match with this:(taken from library)
610171 FORD 28 FRONT 1983-84 RANGER
610223 FORD 28 FRONT 1984 1/2-85 RANGER/BRONCO II
610249 FORD 28 FRONT 1986-87 RANGER/BRONCO II
610298 FORD 28 FRONT 1987 1/2 RANGER/BRONCO II
610300 FORD 35 FRONT 1990 RANGER/BRONCO II
610307 FORD 28 FRONT 1988-89 RANGER/BRONCO II
610365 FORD 35 FRONT 1990 1/2-92 1/2 RANGER/BRONCO II
610366 FORD 35 FRONT 1990 1/2-92 1/2 EXPLORER
610410 FORD 35 FRONT 1993-94 1/2 EXPLORER ABS
610418 FORD 28 FRONT 1993-94 1/2 RANGER (Hybrid axle)
610419 FORD 35 FRONT 1993-94 1/2 RANGER
610436 FORD 35 FRONT 1992 1/2 RANGER
610437 FORD 35 FRONT 1992 1/2 EXPLORER
610476 FORD 35 FRONT 1995 EXPLORER - DISCONNECT (SLA IFS)
610483 FORD 35 FRONT 1995-97 1/2 RANGER ABS
610484 FORD 28 FRONT 1995-97 1/2 RANGER ABS (Hybrid axle)
610556 FORD 35 FRONT 1998 EXPLORER - NON DISCONNECT (SLA IFS)
610581 FORD 35 FRONT 1995-96 EXPLORER - DISCONNECT (SLA IFS)
610582 FORD 35 FRONT 1995-96 EXPLORER - DISCONNECT (SLA IFS)
610585 FORD 35 FRONT 1996 EXPLORER - NON DISCONNECT (SLA IFS)
610586 FORD 35 FRONT 1996 EXPLORER - NON DISCONNECT (SLA IFS)
610642 FORD 35 FRONT 1998-98 1/2 EXPLORER - NON-DISCONNECT (SLA IFS)
610643 FORD 35 FRONT 1998-98 1/2 EXPLORER - NON-DISCONNECT (SLA IFS)
610644 FORD 35 FRONT 1997 1/2 EXPLORER - NON-DISCONNECT (SLA IFS)
610645 FORD 35 FRONT 1998-98 1/2 EXPLORER - NON-DISCONNECT (SLA IFS)
610652 FORD 35 FRONT 1997-97 1/2 RANGER
610653 FORD 28 FRONT 1997 RANGER NON ABS (Hybrid Axle)
610774 FORD 35 FRONT 1999 EXPLORER - NON-DISCONNECT (SLA IFS)
From the above, we can see BOM #s:
610418
610484
610653
Are the Dana 35 "hybrid" axles with the Dana 28 guts.
hope this helps u out
