Wheels debate(still)
Dhunter839
I'm still tore about which wheels to get. I think Hesse would fit but there made for a race car. My truck stis low and I know I don't ever put much weight. Help
if it doesnt say theyre DOT approved, they probably arent. i wouldnt run them for legality reasons. sure, you probably would get away with it but you never know.
they dont list a bore diameter, you may want to double check on that. they also dont specify they are DOT approved, but id have a hard time believing those arent.
I know the center bore would fot because the cragars I started to buy have a 3.300 inch center bore and they fit just fine. Would the backspace and offset be okay? I know on the cragars I was looking at had a 4 inch backspace and they worked
these are gonna sit inboard an inch farther than the cragers. i dont have any experience with a backspace that deep, maybe someone else can chime in? last set of wheels i bought were 15x10 with a 3.5" backspace, they stick way out there haha
I don't have any idea how that much B.S. would fit in front either, seems a tad too much. With the set-up you have now, how much clearance do you have at full crank and allowing for suspension travel?
Dave
