R***A**N**G**E***R
- Oct 3, 2009
- Automatic
So I slid sideways on a small patch of black ice towards the end of winter while going around a corner at about 15 to 20 mph the truck kicked out from under me and my left rear wheel hit the curb and then bounced up into the grass, I went completely up into the shoulder off of the road so I got out to see if there was any damage or a flat tire, well my tire was not flat but I did see a half in long defect in my rim where the tire bead sits.
I then backed up off the shoulder and back onto the street and started to drive and I decided to look out my side view mirror to see if my rim was bent and sure enough it was wobbling back and forth a bit while driving so I ASSUMED my rim was bent well the next day I decided to check my air pressure and it was down about 10 pounds so I new I was loosing air around the area of the rim/bead that bounced off the cement curb.
After a couple weeks of putting air in the tire every couple of days I finally got a new rim and had it swapped out so now I am not loosing air anymore but I still have the wobble, I made sure the new rim was not bent in any way before they mounted it so my question is what is most likely BENT since it is NOT my rim. Please don't tell my my AXLE is bent
