Wheel Size Question
ajward
Hey All...
My '90 Ranger has a set of non-stock tires... 215-75R-15. I like them, except for the occasional wheel well rub on a big bump!
Problem is, I don't have a spare and I don't know what size wheel I need. Any thoughts?
Appreciate any wisdom!
Amanda
The 215-75R-15 tires are approx. 28" in diameter, so any wheel that fits the bolt pattern with a tire that is close to 28" diameter will work for a spare.
You can use a smaller diameter, space-saver spares are used on cars, so a 25" should be fine to get you home or to the flat repair shop.
The stock wheel and tire was probably a 195-70R14, look on the drivers door label.
That wheel and tire is 25"
